JKMBama24 Posted June 16, 2010 Share Posted June 16, 2010 I'm looking for a good Lexus mechanic in the Charleston SC area. My ES300 cooling fans wont turn off. If I don't unhook the battery post, they'll run the battery down. There are no lights on stating a problem. Read a little about it possible being a temp sensor but I really don't want to just change parts. I'd rather a mechanic look at it. Any suggestions? Quote Link to comment Share on other sites More sharing options...
mkeeney Posted June 17, 2010 Share Posted June 17, 2010 I'm looking for a good Lexus mechanic in the Charleston SC area. My ES300 cooling fans wont turn off. If I don't unhook the battery post, they'll run the battery down. There are no lights on stating a problem. Read a little about it possible being a temp sensor but I really don't want to just change parts. I'd rather a mechanic look at it. Any suggestions? You don't need a Lexus-specific mechanic. Any capable mechanic will be able to diagnose your problem. Ask around the area and find out who other people use. I like to use small independent places where the guy in charge is doing a lot of the work. I stay away from places like Pepboys and Sears. Google is great because it will often have reviews of businesses in your area. In the meantime it there may be a connector you can unplug to the fans instead of disconnecting the battery and erasing all your settings. Quote Link to comment Share on other sites More sharing options...
BoaR Posted June 17, 2010 Share Posted June 17, 2010 I'll toss in quick that mkeeney is pretty much right. thats what to look for. if you are "stuck" then find a camry mechanic. the cars are literally the same thing. ;) Quote Link to comment Share on other sites More sharing options...
JKMBama24 Posted June 17, 2010 Author Share Posted June 17, 2010 Thanks B) Quote Link to comment Share on other sites More sharing options...
