rickh Posted June 14, 2010 Share Posted June 14, 2010 03 LEXUS SC430 HAS A LOUD CLICK FROM FRONT END WHEN FIRST BRAKING AT LOW SPEED WHEN CAR IS FIRST MOVED. ONLY HAPPENS WHEN CAR HAS SAT STILL. ANYONE HAVE ANY SUGGESTIONS? Quote Link to comment Share on other sites More sharing options...
intakerGS Posted June 30, 2010 Share Posted June 30, 2010 Yes, be gentle with your caps-lock and check your pistons. Quote Link to comment Share on other sites More sharing options...
Jay Dee Posted July 12, 2010 Share Posted July 12, 2010 And do not type all capitals :chairshot: Quote Link to comment Share on other sites More sharing options...
peter townsville Posted January 20, 2013 Share Posted January 20, 2013 I had the same problem. It is the clips on the brake pads. The OEM pads move forward and back in the caliper. The position of the clips change when you reverse and then drive forward. Replaced them with Bendix ceramic pads and had them fitted by a brake specialist. problem solved Quote Link to comment Share on other sites More sharing options...
