turboomni Posted June 5, 2010 Share Posted June 5, 2010 Anyone have any experience with these swaybar bushings and are they stiffer or softer than stock?? Quote Link to comment Share on other sites More sharing options...
billydpowell Posted June 5, 2010 Share Posted June 5, 2010 Anyone have any experience with these swaybar bushings and are they stiffer or softer than stock?? I used the Moog bushings on mine (part# K90540) and I cant tell them from OEM. car is steady, no leans... I would use them again Quote Link to comment Share on other sites More sharing options...
turboomni Posted June 5, 2010 Author Share Posted June 5, 2010 Anyone have any experience with these swaybar bushings and are they stiffer or softer than stock?? I used the Moog bushings on mine (part# K90540) and I cant tell them from OEM. car is steady, no leans... I would use them again Thanks for the reply!. Glad you are happy with them . Since Daizen are now unavailable at least to me I will use the Moog fronts as you have done and use the Energy Suspension urethane rear bushings to tighten up that spindly little rear swaybar my 1997 has. You said "no leans" I thought they all leaned to some extent. Thanks Quote Link to comment Share on other sites More sharing options...
billydpowell Posted June 6, 2010 Share Posted June 6, 2010 Anyone have any experience with these swaybar bushings and are they stiffer or softer than stock?? I used the Moog bushings on mine (part# K90540) and I cant tell them from OEM. car is steady, no leans... I would use them again Thanks for the reply!. Glad you are happy with them . Since Daizen are now unavailable at least to me I will use the Moog fronts as you have done and use the Energy Suspension urethane rear bushings to tighten up that spindly little rear swaybar my 1997 has. You said "no leans" I thought they all leaned to some extent. Thanks I meant no EXCESSIVE leans.... and my 97 has 247K on it. Quote Link to comment Share on other sites More sharing options...
turboomni Posted June 6, 2010 Author Share Posted June 6, 2010 Anyone have any experience with these swaybar bushings and are they stiffer or softer than stock?? I used the Moog bushings on mine (part# K90540) and I cant tell them from OEM. car is steady, no leans... I would use them again Thanks for the reply!. Glad you are happy with them . Since Daizen are now unavailable at least to me I will use the Moog fronts as you have done and use the Energy Suspension urethane rear bushings to tighten up that spindly little rear swaybar my 1997 has. You said "no leans" I thought they all leaned to some extent. Thanks I meant no EXCESSIVE leans.... and my 97 has 247K on it. I see,,thanks for the info. I'm going to order some. Quote Link to comment Share on other sites More sharing options...
