Dash Board Noise
bought my 10 is250 rwd with all packages. drove for 400 miles now and realized that if i don't warm up the car, i would hear the dashboard making popping noise or sounded like two electrical wires approaching each other to sparkle...
i know some of the previous versions have the same issue, anyone knows why?
If it's a creaking/ticking noise, this is common. Tell the dealer about it when you take it in for the 5000 mile checkup, there's a couple of things they can do that may reduce or eliminate the problem.
They either spray silicone on the mating surfaces or stick some thin felt onto those surfaces. If that doesn't work, there's not much else they can do (unless it's a rattle and something is loose).
