2001 Tail Light Part Numbers
tdishon
I have a 1999 Rx300 and want to put the 2001 tail lights on the rear. What are the part numbers for the four tail lights and do I need the wiring harnesses to? If so, what are the part numbers. Thanks for any help.
You're gonna get them brand new? I'd try to find them used, either from ebay or a local junkyard. Brand new the whole set will put you back $1000. Used, you could probably find the whole set for < $300...
I'm not sure if the plugs for the wiring would be exact, you might have to do some cutting and soldering, that's all.
