kuziwk Posted May 31, 2010 Share Posted May 31, 2010 Any tips? The rubber is hard, what if pieces crack into the crankcase? Shouk I try a heatgun? Quote Link to comment Share on other sites More sharing options...
RDM Posted May 31, 2010 Share Posted May 31, 2010 PCV. Not PCP. The grommet always dries up and breaks apart, it just falls into a small valley in the valve cover, not down into the cylinder head. Break it as little as you can, then use a pick, needle nose pliers, or anything similar to get the pieces out of the area they fall into. Quote Link to comment Share on other sites More sharing options...
landar Posted May 31, 2010 Share Posted May 31, 2010 You might also clean the old grommet of oil/grease and cut a piece of adhesive tape (like duct tape) to go over the grommet. When the grommet starts to break apart, the smaller pieces will adhere to the tape and make the cleanup easier. Quote Link to comment Share on other sites More sharing options...
kuziwk Posted May 31, 2010 Author Share Posted May 31, 2010 You might also clean the old grommet of oil/grease and cut a piece of adhesive tape (like duct tape) to go over the grommet. When the grommet starts to break apart, the smaller pieces will adhere to the tape and make the cleanup easier. hmm good idea about the tape, yea sorry pcv....stupid iphone, anyways how can i pull up on the plug ive tried my best and if i cant get it i dont know who can as i work out three days a week and im far from weak...lol. Is there a tool i can use besides pliers? Quote Link to comment Share on other sites More sharing options...
dpellet Posted June 3, 2010 Share Posted June 3, 2010 Steady pull pressure and a figure 8 motion. It will eventually come out. Mine was old and took a bit to get out as well.. Pliers worked for me but I replaced it with a new one anyway. Regards, Quote Link to comment Share on other sites More sharing options...
