Sign in to follow this
Luis Arnel
Transmission's Panel Light Indicator
Hi again guys! My GS have a problem that both panel and shifter base indicator don't synchronize with the shiffter position. Example, when I place shift in "2", the "D" light came on (is the only time panel indicator works). Is there a sensor malfuntion? which one is to order it?
Thanks again!
Luis
Share this post
Link to post
It's called the Neutral Safety Switch. It's on the side of the transmission above the exhaust. It's somewhat difficult to get at. It is possible that the shifter linkage to it has loosened but more likely that it is failing. p/n 84540-30270, about $110.00 retail if you look for the (Toyota) part number given. Note that this switch, if bad can cause the car to not start or start with the shifter in a position other than "P" or "N", which can be dangerous.
Share this post
Link to post
Loading...
