igbeserk Posted May 25, 2010 Share Posted May 25, 2010 When I was taking apart parts of the engine to get to the knock sensor, me and my friend took a look at the throttle body it doesn't seem to open all the way it at most opens diagonally instead to the full horizontal. Then again i'm not sure if it's supposed to open all the way but from seeing other cars I believe it should. How could i resolve this issue? would i need to tighten something around there so the valve could open all the way? Any help would be appreciated. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
igbeserk Posted May 29, 2010 Author Share Posted May 29, 2010 fixed the throttle body valve. it was the bottom chord the one that when you hit the gas the car pulls on to open it. for some reason it wasn't calibrated to the right position for it to open all the way. so i loosened the bolts around it and pushed it back until the valve opened all the way then i tightened it there. Car picks up like crazy now. getting to 80-100 with ease. hopefully it helps on the mpg it seems like it might have. but yea. at least that's one less issue. Quote Link to comment Share on other sites More sharing options...
98 ES 222K Posted June 25, 2010 Share Posted June 25, 2010 fixed the throttle body valve. it was the bottom chord the one that when you hit the gas the car pulls on to open it. for some reason it wasn't calibrated to the right position for it to open all the way. so i loosened the bolts around it and pushed it back until the valve opened all the way then i tightened it there. Car picks up like crazy now. getting to 80-100 with ease. hopefully it helps on the mpg it seems like it might have. but yea. at least that's one less issue. Quick ? does it idle high and is it still driving good after that quick fix, I think I might need 2 do the same because after cleaning the MAF and the IACV on my 98 es300 it idling high and also has the same thing going on with the throttle body as well? thanks for any input Quote Link to comment Share on other sites More sharing options...
igbeserk Posted June 27, 2010 Author Share Posted June 27, 2010 fixed the throttle body valve. it was the bottom chord the one that when you hit the gas the car pulls on to open it. for some reason it wasn't calibrated to the right position for it to open all the way. so i loosened the bolts around it and pushed it back until the valve opened all the way then i tightened it there. Car picks up like crazy now. getting to 80-100 with ease. hopefully it helps on the mpg it seems like it might have. but yea. at least that's one less issue. Quick ? does it idle high and is it still driving good after that quick fix, I think I might need 2 do the same because after cleaning the MAF and the IACV on my 98 es300 it idling high and also has the same thing going on with the throttle body as well? thanks for any input no i don't remember it idling high it always seems to be at the same position. well check your throttle body it's supposed to open halfway if its not then you have to fix it. drives good, responds well, gets to higher speeds quicker. Quote Link to comment Share on other sites More sharing options...
