Traction Control Rx 400H
I just learned how you can turn off the Traction Control system on an RX 400h:
1. Switch the car off, then switch it on without (ready) light.
2. While on P, press the gas pedal 4 times.
3. Shift to N, press the gas pedal 4 times.
4. Shift to P again, press gas pedal 4 times.
5. Switch the car to ready and drive (at your own risk) without computer controlled wheels!
The next time you start the car it will be back to normal again.
Waaat... is this really working? Anyone tested this?
haa yeah works like charm today I tested at beach in sand first went normally and honestly was pretty nervous and thought I will not get back car struggled massively with stupid traction control. Then using this method switched VSC off and car showed AWD maintenance mode, then went again same route and it was much more fun :) get out very easily of course... I just hope I don't do any harm with this not sure what exactly mean AWD maintenance mode?
  • 1 year later...
Hey!
I have a RX400H 2007 and I have been trying this trick for several times but no luck so far :(
Could someone please tell me what this means "1. Switch the car off, then switch it on without (ready) light." I'm not sure how to do this since every time I start the car the ready light is already on?
Perhaps I'm just stupid but I would really need to figure this out since where I'm living we have a lot of snow.
Thanks already for your help!
28 minutes ago, Sam_O said:
Hey!
It means that you turn the key only until it's in the "on" position, not all the way to "start".
If you see "ready" on the display you have turned too far.
Ok thanks! I tried that also but it doesn't work :(
I have european car so perhaps that is the reason.
Strange, it's the first time I have heard that it's not working. I'm in Sweden and it works for me.
You should fully push and fully release the gas pedal each time.
I'm in Finland ;)
Now I got it working! My error was to use break pedal to be able to shift from the P. Now I realised that you don't have to do that if you keep the stick to the very right.
Tusen tack!
  • 2 months later...
This work for me
06 rx400h awd, gen 2 Prius
1: turn ignition ON no brake,  key or button.
2: press and hold brake whole process
3: press gas pedel to floor twice
4: put car in nutral, press gas pedel to floor twice.
5: put car in park, press gas pedel to floor twice.
6: foot still on brake, start the car key or button.
then release brake and you are done
resets itself when car is turned off
  • 2 months later...
On 10/17/2016 at 0:02 AM, Got2bnu said:
This work for me
So I did both directions and I found out something in case anyone hasn't.
If you press gas pedal 2 times that front wheel drive only. And 4 times in OP is awd mode. I have awd 400h so not sure it the rear electric modors would deplete battery quickly if doing donuts or stuff in snow
Anyone have any experience?
Thanks,
  • 2 years later...
