pete rock Posted May 10, 2010 Share Posted May 10, 2010 hi guys just a simple question.ive had my es for almost 2 years now.and not positive the last time the previous owner changed the spark plugs or wires.id like to do this to my car.i know you guys are very informative with specific plugs you like.my car has around 107k on her and i do drive her a good bit.so any recommendation on plugs and wires id greatly appreciate Quote Link to comment Share on other sites More sharing options...
gbhrps Posted May 11, 2010 Share Posted May 11, 2010 Your best bet is to check your owner's manual for the correct make and spark plug number, and then get the plugs and the wires from a Toyota dealer. A lot of after market wires are too long, too short, or have the incorrect plug covers that just won't fit. Quote Link to comment Share on other sites More sharing options...
sparkybuoy Posted May 21, 2010 Share Posted May 21, 2010 Original plugs in that car were either Nippondenso (Denso) or NGK Platinum plugs that were rated at 60k miles - you can upgrade to Iridium and go 100k miles on those - Kragen and NAPA sell the NGK Iridiums for like $7 each - If the vehicle isn't misfiring and it isn't being caused by a wire...leave them alone...the factory Sumitomo wires last almost forever - don't ever change the cap and rotor either unless it's actually causing a problem - one last thing...there's no need and no recommendation to change the factory Nippondenso fuel filter...ever! It's designed not to plug up. Quote Link to comment Share on other sites More sharing options...
