Ls460 18" Wheels Fit An Rx300?
Hello, I am new to this club but not to my RX300. I bought it new in May 1999 and just went over 100,000 miles. My Question: I have an opportunity to buy a set of new LS400 18" takeoff wheels at a great price. Is there any reason they will not fit my RX300? I know there is no fitment problems with the 18" and should not be with the 7.5" width. Is there a different bolt pattern between the two cars? Any help would be most appreciated. Regards to All
I doubt it, but you can probably find out from the following dimensions:
Hub bore diameter
Offset
Bolt circle diameter/distance
If all of these match up between the stock RX300 wheels and the LS400 wheels (what year?), then there's a very good chance they will fit (the brakes on the RX300 are smaller than the LS400, so clearance shouldn't be an issue).
