stroker Posted April 27, 2010 Share Posted April 27, 2010 I'm trying to get the air control valve off of the P/S pump and it seems like its an 11/16 but not sure; also normal wrench gives no room to loosen or tighten.. I plugged both lines going to the engine and even with the spring clips on the hoses, when you run the engine I guess the pressure pops off one of the lines at the valve.. Any help would be appreciated, Thanks, Bobby Quote Link to comment Share on other sites More sharing options...
curiousB Posted April 27, 2010 Share Posted April 27, 2010 metric Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 28, 2010 Share Posted April 28, 2010 Ah ha, you are in luck because I happened to have one in my toolbox so I just went out to the garage and measured up. You need a 17mm for this valve. By the way, I got this one off a Camry at a junkyard, they are the same. I will go over to Fastenall when I get a chance and pick up a bolt with the same threads, some locktite and close it up. Quote Link to comment Share on other sites More sharing options...
stroker Posted April 28, 2010 Author Share Posted April 28, 2010 I finally found a 17mm wrench (had to buy a set of stubbies). They are about 5 inches long so I should be able to get in there to take the old valve out. What a dirty job! Also picked up a bolt and am going to just seal it up for good I hope. I just want to thank you for the info and am glad to see that there are more people like yourself on this forum...Thanks again, Bobby Ah ha, you are in luck because I happened to have one in my toolbox so I just went out to the garage and measured up. You need a 17mm for this valve. By the way, I got this one off a Camry at a junkyard, they are the same. I will go over to Fastenall when I get a chance and pick up a bolt with the same threads, some locktite and close it up. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 30, 2010 Share Posted April 30, 2010 Thanks Stroker. Just one of the many things I have accumulated in knowledge of the cars. Quote Link to comment Share on other sites More sharing options...
