Brake Light Does Not Work
marcjj
I have a 2003 RX300. The warning light came on indicating a brake light needs replacing - turns out the inside right light is out. I've tried replacing (tried several bulbs) and the light still won't work. Any suggestions? Thanks.
The problem is usually with the socket when this happens. Look inside and see if oith of the contact pins are at the same height and in decent condition. I've had the pins stick before and cause this to happen.
