charlieGS350 Posted April 24, 2010 Share Posted April 24, 2010 My 07GS350 AWD has 41K miles. Yesterday I noticed the rear end is not leveled. So I did a measurement. The driver's side wheelwell is about 1mm lower than the passeneger's side. The tire pressure is the same on two rear tires. It's too early for a shock absorber to go bad. The front end is completely leveled. Any GS350 AWDs owners experience the same? Quote Link to comment Share on other sites More sharing options...
The G Man Posted April 26, 2010 Share Posted April 26, 2010 My 07GS350 AWD has 41K miles. Yesterday I noticed the rear end is not leveled. So I did a measurement. The driver's side wheelwell is about 1mm lower than the passeneger's side. The tire pressure is the same on two rear tires. It's too early for a shock absorber to go bad. The front end is completely leveled. Any GS350 AWDs owners experience the same? Could be a leaking shock. Quote Link to comment Share on other sites More sharing options...
charlieGS350 Posted April 26, 2010 Author Share Posted April 26, 2010 My 07GS350 AWD has 41K miles. Yesterday I noticed the rear end is not leveled. So I did a measurement. The driver's side wheelwell is about 1mm lower than the passeneger's side. The tire pressure is the same on two rear tires. It's too early for a shock absorber to go bad. The front end is completely leveled. Any GS350 AWDs owners experience the same? Could be a leaking shock. I think so. My in-law had the rear shocks replaced twice for her Camry with 56K miles on the odometer. Today it's almost 1.5 mm lower. Made appt. for Wed. Quote Link to comment Share on other sites More sharing options...
Transconductor08 Posted April 27, 2010 Share Posted April 27, 2010 Am I reading your measurement correctly?? 1.0 mm??? Did you mean 10.0mm?? 1.0 Inch? I just came back from Lexus with my 06 GS300 with 1.5 cm difference, which is over 1/2 inch left-sided lean and they said this was neglibible. Am I missing something? Quote Link to comment Share on other sites More sharing options...
charlieGS350 Posted April 27, 2010 Author Share Posted April 27, 2010 Am I reading your measurement correctly?? 1.0 mm??? Did you mean 10.0mm?? 1.0 Inch? I just came back from Lexus with my 06 GS300 with 1.5 cm difference, which is over 1/2 inch left-sided lean and they said this was neglibible. Am I missing something? I stand corrected. You're right. It's 1.5 cm or almost 3/4 inch. I can stand 10 feet from the rear and see the rear end tilted on one side. My in-law has an 2002 ES300 and the rear end levels on both side. If it's 0.5 cm, I can say it's negligible. But it's 1.5 cm, I don't think so. Quote Link to comment Share on other sites More sharing options...
Transconductor08 Posted April 27, 2010 Share Posted April 27, 2010 Well you will need to update this post when you find out. One thing I notice is that the lean changes. I have measured mine in my garage, after driving and over a week or so. The lean varies over 1/2". Either way, the dealership says this is normal. I bet alot of others probably have the same "issue" but don't notice. Quote Link to comment Share on other sites More sharing options...
The G Man Posted April 28, 2010 Share Posted April 28, 2010 Well you will need to update this post when you find out. One thing I notice is that the lean changes. I have measured mine in my garage, after driving and over a week or so. The lean varies over 1/2". Either way, the dealership says this is normal. I bet alot of others probably have the same "issue" but don't notice. This is a common problem with the Lexus GX470, my old GX used to sag on one side by about 1/2". Some owners complains about 1 side sagging as much 2 inches. The sag does varies from time to time, its almost like it depends on how the suspension settles after you go for a drive. Of course you need to make sure you are on level ground when making the measurement. Quote Link to comment Share on other sites More sharing options...
charlieGS350 Posted April 29, 2010 Author Share Posted April 29, 2010 Well you will need to update this post when you find out. One thing I notice is that the lean changes. I have measured mine in my garage, after driving and over a week or so. The lean varies over 1/2". Either way, the dealership says this is normal. I bet alot of others probably have the same "issue" but don't notice. Dealership says it's normal. Suspension is tight. No leak. What a disappointment for a $50K car. Quote Link to comment Share on other sites More sharing options...
charlieGS350 Posted April 29, 2010 Author Share Posted April 29, 2010 Well you will need to update this post when you find out. One thing I notice is that the lean changes. I have measured mine in my garage, after driving and over a week or so. The lean varies over 1/2". Either way, the dealership says this is normal. I bet alot of others probably have the same "issue" but don't notice. This is a common problem with the Lexus GX470, my old GX used to sag on one side by about 1/2". Some owners complains about 1 side sagging as much 2 inches. The sag does varies from time to time, its almost like it depends on how the suspension settles after you go for a drive. Of course you need to make sure you are on level ground when making the measurement. I guess after reading this, less than one inch sagging is normal. http://www.aa1car.com/library/ride2h.htm Quote Link to comment Share on other sites More sharing options...
