yank30265 Posted April 23, 2010 Share Posted April 23, 2010 my 1990 ls400 car alarm goes off when 30 sec after i lock the doors. Any ideas what this could be? I have heard there could be a button under the dash to shut down the alarm; any ideas on where or if thie might be? Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 25, 2010 Share Posted April 25, 2010 I would have to guess that one of the switches that controls the inside lights when you open and close the doors is sticking. I know on my 90 LS, sometimes when you open the door, the lights don't not come on and I have to flick the switch. I never had it cause the alarm to go off but it must also have something to do with the alarm. Quote Link to comment Share on other sites More sharing options...
RDM Posted April 25, 2010 Share Posted April 25, 2010 There is no valet/override button on the OE alarm. It is triggered by opening the doors, trunk, or hood, so first narrow it down as to which one is triggering it. The door switches do stick but they wouldn't stick open if the door was closed, unless one is broken, so go around and try each one manually to see if they work correctly. That's pretty simple to do and will eliminate those as the culprit. Next try the trunk, arm the alarm and then press down on the lid, maybe even lean on it, until the 30 seconds passes. The switch is located in the latch and may be worn enough that it doesn't trip unless there's a load on it, like the trunk fitting tighter. If that's not it it's the hood switch, which I believe is located behind the latch itself. The hood latch is not adjustable on these cars so you may just need to order a new switch since you can't tighten the tension on it at all. Quote Link to comment Share on other sites More sharing options...
yank30265 Posted April 25, 2010 Author Share Posted April 25, 2010 There is no valet/override button on the OE alarm. It is triggered by opening the doors, trunk, or hood, so first narrow it down as to which one is triggering it. The door switches do stick but they wouldn't stick open if the door was closed, unless one is broken, so go around and try each one manually to see if they work correctly. That's pretty simple to do and will eliminate those as the culprit. Next try the trunk, arm the alarm and then press down on the lid, maybe even lean on it, until the 30 seconds passes. The switch is located in the latch and may be worn enough that it doesn't trip unless there's a load on it, like the trunk fitting tighter. If that's not it it's the hood switch, which I believe is located behind the latch itself. The hood latch is not adjustable on these cars so you may just need to order a new switch since you can't tighten the tension on it at all. my lights dim when i hit the brakes or turn on the fan etc.. then they go bright agian in the blink of an eye ; people have told me this is the wire on the left side of trunk; unwrap and ill find the white wire is broken; could this b the culprit? i checked those wires and didnt find a boken wire as far as I could see; but do u think these r connescted? Quote Link to comment Share on other sites More sharing options...
