1994 Es300 Front Dome Light Replacement
Pry the light lens out -- looks like it is held in by friction like on other Toyota and Lexus sedans -- see the attached diagram.
Thank you so much for the info. In the diagram, it seems to be the Balloon 5 area that shows what I need, but it is chopped off somehow. Do you have that part of the diagram? Thanks a lot again.
All the little light lenses are held in place by friction and little plastic tabs on the lenses.
Thanks! I finally removed the plastic frame together with the lens. The lens was plastically revited onto the frame at four points.
