Vinodh Posted April 19, 2010 Share Posted April 19, 2010 Hi Guys, I have a 99 ES300. Today while driving I got this VSC OFF indication, VSC indication(on the left of the panel) and the Check engine indication all at a time. Are they all interlinked? Engine did not overheat and the heat indicator needle stayed little less than halfway in it's scale, as usual. I did an oil change on February. What do you do when you were in such position, like a self check for problems? I looked into the user manual and could not find any link between VSC and check engine. Any help is appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted April 20, 2010 Share Posted April 20, 2010 Yes, the two warnings are often/usually linked. Think of it as like your PC is going into "safe mode." Have the codes read to find out the real problem -- which usually has nothing to do with VSC. Quote Link to comment Share on other sites More sharing options...
Vinodh Posted April 22, 2010 Author Share Posted April 22, 2010 Yes, the two warnings are often/usually linked. Think of it as like your PC is going into "safe mode." Have the codes read to find out the real problem -- which usually has nothing to do with VSC. I did a code check in Advanced Auto Parts. It read out P0171 (for oxygen sensor/air filter??). The guy asked me if there is anything different in drving or if it drives the same. I didnot feel any difference, so he did reset the code for me. All the three indications went off. 2 days passed and nothing happened and still drives smooth. Thanks for your advice. Quote Link to comment Share on other sites More sharing options...
