aomiups Posted March 28, 2010 Share Posted March 28, 2010 d Quote Link to comment Share on other sites More sharing options...
PK_3 Posted March 28, 2010 Share Posted March 28, 2010 Low oil preassure. Most pronuced when motor is at low RPMs.Could be a bad oil pump or worn engine. Also, If you are low on oil, on braking the oil sloshes to the front of oil pan and dodges the oil pickup. Regards, PK Quote Link to comment Share on other sites More sharing options...
aomiups Posted March 29, 2010 Author Share Posted March 29, 2010 Low oil preassure. Most pronuced when motor is at low RPMs.Could be a bad oil pump or worn engine. Also, If you are low on oil, on braking the oil sloshes to the front of oil pan and dodges the oil pickup. Regards, PK thanks PK ”Could be a bad oil pump or worn engine.“ Does it mean my engine is going to be ruined... the oil signal lights in last week because the loose oil cover. And I was driving more than 200miles after the oil light firstly appears. So, now I guess that my engine is sort of damaged.... Does anybody know the repair cost? Quote Link to comment Share on other sites More sharing options...
pauljcl Posted March 29, 2010 Share Posted March 29, 2010 Low oil preassure. Most pronuced when motor is at low RPMs.Could be a bad oil pump or worn engine. Also, If you are low on oil, on braking the oil sloshes to the front of oil pan and dodges the oil pickup. Regards, PK thanks PK ”Could be a bad oil pump or worn engine.“ Does it mean my engine is going to be ruined... the oil signal lights in last week because the loose oil cover. And I was driving more than 200miles after the oil light firstly appears. So, now I guess that my engine is sort of damaged.... Does anybody know the repair cost? Your original post states that you checked the oil "& there was almost no oil in the tank" (i.e. - I assume the oil level was low? If that is the case, I would suggest immediate refill to the correct level, (and check the oil light then) and also investigate why the oil level is / was low. Quote Link to comment Share on other sites More sharing options...
aomiups Posted March 29, 2010 Author Share Posted March 29, 2010 Low oil preassure. Most pronuced when motor is at low RPMs.Could be a bad oil pump or worn engine. Also, If you are low on oil, on braking the oil sloshes to the front of oil pan and dodges the oil pickup. Regards, PK thanks PK Could be a bad oil pump or worn engine. Does it mean my engine is going to be ruined... the oil signal lights in last week because the loose oil cover. And I was driving more than 200miles after the oil light firstly appears. So, now I guess that my engine is sort of damaged.... Does anybody know the repair cost? Your original post states that you checked the oil "& there was almost no oil in the tank" (i.e. - I assume the oil level was low? If that is the case, I would suggest immediate refill to the correct level, (and check the oil light then) and also investigate why the oil level is / was low. have solved, it is sort of leakage...thanks Quote Link to comment Share on other sites More sharing options...
