Pre Load Cam
mugs
I do not understand, what do you mean by "preload"? Do you mean a valve adj?
The gears on the end of the cam are spring loaded and I should have put a bolt through the gears to keep them from moving I did not and now I need to pre load or put the gear back before I can put it back on the head
Sen me a PM with you email, I will send the section of the manual that shows the install procedure.
I don't know what PM is but here is my e-mail chris.ortiz@navy .mil
the car is 94 es300
