How To Change / Add Trans Fluid
NOSZ06
1994 LS430 64K MILES
I would like to change trans filter and fluid. What is the procedure to add fluid after changing filter and draining tranny?
No dip tube to add fluid. Is there a sight / fill plug on the transmission case?
Help
If thats the case than I would put that car up for auction. It's really REALLY rare to see a 1994 LS430 not to mention the ultra low milage.
JK
If its a 94 check out lexls. If its a LS430 good luck. The tranny is supposedly sealed for life. There should be a drain and filler plug on the tranny though. The filter I cant say for sure about.
  • 1 month later...
Sorry for the mistake.
Typo...My car is a 2004 LS430
Their is no transmission fill tube/dip stick to check or add transmission fluid.
Question: Is their a fill plug and where is it located?
Thanks for your replies.
Well Lexus doesn't have a level check tube or convenient fill port as the unit is lubricated for >100K miles from the factory. Hard to believe this is a good idea maybe they looked at the risk of incorrect fluid or too much fluid added and said its actually better to not let owners or inexperienced maintenance people play around with fluids.
What kills me is my dealer lists transmission fluid flush as a service at the 30/60/90k service intervals and I thought I was paying to have this done yet it never has been......
There is a fill and drain port underneath the car of the side of the transmission case if you really want to get in there
