..for your high beam/DRL bulbs?
Led's won't last in there. There isn't a pair of pnp LED 9005 replacements with enough heat-sink and voltage regulation to last more than... maybe a month with regular use. Nor will they be bright enough to be seen during the day nor even be somewhat adequate when you need your high beams at night or for signaling. You'd also need to run a load resistor as the LED's will make the computer the bulbs are out and will shut the circuit.
yea i never use my highs anyway, the HID system i have makes the HIbeams seem usless anyway. where would i beable to pick up a load resistor and/or how much of a load am i resisting???
no resistor needed for the '99... works wonderfully well... bought from motoringmax on ebay for 49.99 free shipping
  • 7 months later...
9005 is amazing, this is the next generation of HI-Power LED arrays drawing much more current and making 5 times the power of an incandescent bulb. But as far as I know it won't fit to your 99 but if you want it to get fit for GS400 98 , then it's possible with it.
