need help
How do you remove the glove box 1997 LS400
I tried to use this:
To the bottom right of the glovebox is a 10 mm bolt. Unbolt it (you may have one on each side. These bolts loosen the glovebox assembly. This along with some phillip screws drops the entire glovebox assembly. There is also a panel that attaches to the glovebox assembly. I think it has 3 clips that when pulled, comes off. A floor light may be attached to your panel, so don't pull it too far or hard..leave all that intact..no biggy.
There are also phillips screws and a few more 10mm bolts, but if you remove the 1 or 2 that loosen the glovebox assembly, the rest is very simple.
I DO NOT SEE ANY BOLTS TO REMOVE??????
I DO NOT SEE ANY BOLTS PERIOD!!
CAN ANYONE HELP??
I HAVE REMOVED THE 3 CLIP PANEL..
Super!
BTW, your glasses are up on your forehead. Just in case you were wondering. :o
Super!
yep, pinching my brain ......... that is the ONLY nut in this car that is not "covered"
what a relief...
