billydpowell Posted March 3, 2010 Share Posted March 3, 2010 need help How do you remove the glove box 1997 LS400 I tried to use this: To the bottom right of the glovebox is a 10 mm bolt. Unbolt it (you may have one on each side. These bolts loosen the glovebox assembly. This along with some phillip screws drops the entire glovebox assembly. There is also a panel that attaches to the glovebox assembly. I think it has 3 clips that when pulled, comes off. A floor light may be attached to your panel, so don't pull it too far or hard..leave all that intact..no biggy. There are also phillips screws and a few more 10mm bolts, but if you remove the 1 or 2 that loosen the glovebox assembly, the rest is very simple. I DO NOT SEE ANY BOLTS TO REMOVE?????? I DO NOT SEE ANY BOLTS PERIOD!! CAN ANYONE HELP?? I HAVE REMOVED THE 3 CLIP PANEL.. Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted March 3, 2010 Share Posted March 3, 2010 See if this helps: http://www.clublexus.com/forums/288233-post2.html Quote Link to comment Share on other sites More sharing options...
billydpowell Posted March 3, 2010 Author Share Posted March 3, 2010 See if this helps:http://www.clublexus.com/forums/288233-post2.html YES, YES, YES... I finally saw that silly nut, right out in plain site ... probably why I didnt see it. thank you AZ............ Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted March 3, 2010 Share Posted March 3, 2010 Super! BTW, your glasses are up on your forehead. Just in case you were wondering. :o Quote Link to comment Share on other sites More sharing options...
billydpowell Posted March 3, 2010 Author Share Posted March 3, 2010 Super!BTW, your glasses are up on your forehead. Just in case you were wondering. :o yep, pinching my brain ......... that is the ONLY nut in this car that is not "covered" what a relief... Quote Link to comment Share on other sites More sharing options...
