eijitoyoda Posted February 23, 2010 Share Posted February 23, 2010 I was wondering how much weight can the self leveling suspension (safely) take? I am always concerned when hitching up a trailer with a significant tongue weight as I don't want the suspension to "over exert itself" and be ruined. Any ideas? Also, my intention is not too put as much weight as possible on the tongue but I am not really sure what the best method is to estimate tongue weight. Quote Link to comment Share on other sites More sharing options...
xxstewart Posted February 23, 2010 Share Posted February 23, 2010 The factory hitch is a class III rated for 6,000 lbs towing and 600 lbs hitch weight. The suspension should be able to handle the hitch rating (certainly no worse than 3 adults in your back seat, but I wouldn't do the trailer at the same time). You can buy hitch scales for about $100 if you're uncertain about the trailer's weight distribution. Distributing the weight properly is critical (see your trailer owner's manual) -- too little tongue weight is as bad as too much. If your trailer is back-heavy, the hitch can pop off the ball, or the trailer can go into a fishtail and you can flip your car. Quote Link to comment Share on other sites More sharing options...
