vdeleon Posted February 4, 2010 Share Posted February 4, 2010 Anyone know's the actual size of the socket to replace O2 sensor (bank 1-before the CAT) ? Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 4, 2010 Share Posted February 4, 2010 Anyone know's the actual size of the socket to replace O2 sensor (bank 1-before the CAT) ? There is a special socket made just for 02 sensors, The socket has a gap running the length of the socket so you can get over the wire. I beleive it is a standard size. Quote Link to comment Share on other sites More sharing options...
vdeleon Posted February 4, 2010 Author Share Posted February 4, 2010 Anyone know's the actual size of the socket to replace O2 sensor (bank 1-before the CAT) ? Thanks for the input but I need to know the exact size, whether it's a 22mm or something else.I'm aware what kind of socket (wiring gap)you need to use but not the actual size. I read a post by one member that he bought a standard size sensor socket and it would not fit. Don't want to waste time getting the wrong one. Anyone here actually used one? Quote Link to comment Share on other sites More sharing options...
RDM Posted February 4, 2010 Share Posted February 4, 2010 Standard size is 7/8", 99% of oxygen sensors work with that size fine. Some sensors may feel loose but it's rarely an issue. Quote Link to comment Share on other sites More sharing options...
vdeleon Posted February 4, 2010 Author Share Posted February 4, 2010 Standard size is 7/8", 99% of oxygen sensors work with that size fine. Some sensors may feel loose but it's rarely an issue. That's what I thought but not entirely sure, Thanks. ;) Quote Link to comment Share on other sites More sharing options...
