yidaitianjiaous Posted January 13, 2010 Posted January 13, 2010 Help.......92/LS-400 about 170,000 Miles. This morning i started car and Battery, Brake and Oil light won;t go off. As I know, these lights go off seconds after car started. everything was normal before. fisrt time occurance. Thunder storm at night and is that the cause? Thingking about some fuse reset and get them away? need suggestions. thx
steve2006 Posted January 14, 2010 Posted January 14, 2010 Some one has stolen your battery, brakes and drained the engine oil during the storm! :o Seriously search the forum for "trunk hinge wiring" as this is a common problem causing symptoms you have amongst others. Another possibility is that your battery is on its way out so have it checked.
eatingupblacktop Posted January 14, 2010 Posted January 14, 2010 Do you notice any change when you rev the engine or drive vs idle? If the trunk harness is ok, I'd check your charging system.
