Totally Dead 2000 Rx300
bt11
The 2000 RX300 has been parking more than a year. Totally dead. Replaced a known good battery. Can't even switch any gear even to neutral to push. Checked fuses with Ohm meter and they all seem fine. Where do I start? Any idea? Thanks, Joe
There is a bypass for the gear shift under the little cover piece. Look in your owners manual and it will show the location. Do the ignition display (speedometer, display) lights come on when you turn the key on?
