Door Will Not Open From Outside, Need Help On Door Removal
gs_1993
Hi,
So i pulled off my door panel, and found out that the infamous little plastic clip had broken. When i tried attaching the new one, I managed to break the entire metal piece that the clip clips onto. I then bought this mechanism that sits in between the door panel and the outside of the door, near the very end of the door, from a junkyard, and have no idea how to install the new one. I can't reach my hand in the little cavity to pull the old one out, so I was wondering if anyone has successfully pulled apart the metal pieces to get to this part, and which screws to remove (keep in mind I've already removed the door panel). Thanks for your help in advance.
