ksg Posted January 1, 2010 Share Posted January 1, 2010 Time to time I experienced dimming of lights and accessories for a few seconds, sometimes with erratic running of the engine at the same time. Seemed especially likely with a warm engine when coming down to idle after a run (like getting off highway and entering stop-and-go city traffic). Maybe worse in wet weather. Definitely worse with lots of accessories on or when stepping on the brake pedal. I don't refer to the LED gauge needles which many have posted on - rather it seems to be the whole system. On the alternator I took off the rear cover, voltage regulator and brush holder - there was a great deal of filth on the slip rings and they were also scored all the way around to the point I could feel the grooves with a finger. I have had a similar issue on a couple of other cars in the past. Anyway, I cleaned everything up. It will take a few weeks to know if this helps. Meanwhile I thought it was worth mentioning in case other owners might have the same issue. Sooner or later a new alternator might be needed. Quote Link to comment Share on other sites More sharing options...
lenore Posted January 2, 2010 Share Posted January 2, 2010 I would also check your ground wires going from the battery to the body and the engine block. If they are loose or corroaded they could cause that problem. Quote Link to comment Share on other sites More sharing options...
