Navigation Override
browningr
Have a 2006 RX330 with original navigation system (ver 4) I just replaced the map disk with a new 2009 edition,bought new from Sewell in Dallas. Installed it myself, seems to work just fine except the navigation override procedure that use to work does not.
The procedure I used was: Menu, Volume, upper left corner, left corner, upper left corner ,lower left corner, and then hold the override button 5-10 seconds on the screen that appears.
Have I lost the override option by installing the new 2009 map disc or is there an override for this combination as well !!!!!!!
Yes, version 8.1 and 9.1 disks have the override feature removed. Thank you Lexus for being my parent!
