On my 2004 RX330, the lights that are on the shifting console do not come on, about half the time. It can't be a fuse, since they do work some of the time. Any ideas?
So only the lights on the shifter panel? What about the lights for the heated seats and headlight washer? What about the radio and AC buttons?
These are all on the same circuit- so if the issue is only with the shifter lights, it's most likely the bulb that's maybe loose or burning out. If it's all three areas, then it's a bigger issue...
Nope - Just the shifter panel. Guess you're right, a loose bulb.......Now if I could only figure out how to get to it!
These directions are for a RX300 but they should be the same.
http://www.clublexus.com/forums/rx-first-g...lumination.html
Pry up the wood shifter surround piece with a philips screwdriver, then you'll be able to find it. There's only one bulb i think...
