PJA41 Posted December 4, 2009 Share Posted December 4, 2009 I read there is a sensitivity setting for the automatic wipers but I cannot locate it. Does someone know where it is and if it could be why the auto position does not activate the wipers? Thanks Quote Link to comment Share on other sites More sharing options...
pauljcl Posted December 4, 2009 Share Posted December 4, 2009 I read there is a sensitivity setting for the automatic wipers but I cannot locate it. Does someone know where it is and if it could be why the auto position does not activate the wipers?Thanks On my RX it is a ring near the end of the windshield wiper stalk. You turn it one way for less sensitivity, the other way for more. (The ring is a little like the ring on the lights' stalk, for the fog-lights.) Quote Link to comment Share on other sites More sharing options...
bickleym Posted December 8, 2009 Share Posted December 8, 2009 I read there is a sensitivity setting for the automatic wipers but I cannot locate it. Does someone know where it is and if it could be why the auto position does not activate the wipers?Thanks On the wiper control arm you should see the word 'AUTO' printed on a collar that rotates and aligned with four incrments from '-' to '+'. I leave mine set on the third setting from the '-' which makes it slightly more sensitive but not at maximum sensitive. Also, I have to move the level to the second position for the auto wiper feature to engage. Raising the level as far up it will go is off and the next position down is the automatic setting. The third is 'on' slow and the fourth 'on' fast. Quote Link to comment Share on other sites More sharing options...
PJA41 Posted December 8, 2009 Author Share Posted December 8, 2009 I read there is a sensitivity setting for the automatic wipers but I cannot locate it. Does someone know where it is and if it could be why the auto position does not activate the wipers?Thanks On the wiper control arm you should see the word 'AUTO' printed on a collar that rotates and aligned with four incrments from '-' to '+'. I leave mine set on the third setting from the '-' which makes it slightly more sensitive but not at maximum sensitive. Also, I have to move the level to the second position for the auto wiper feature to engage. Raising the level as far up it will go is off and the next position down is the automatic setting. The third is 'on' slow and the fourth 'on' fast. Thank you... I finally figured it out. Now I'm waiting for it to rain to see if it works! Quote Link to comment Share on other sites More sharing options...
kevinwang Posted December 14, 2009 Share Posted December 14, 2009 i've read somewhere that if you disconnect the automatic rain sensing box (located next to your rear view mirror), you can actually have the intermittent wipers which are missing in the 02 ES's. anyone tried this before? Quote Link to comment Share on other sites More sharing options...
