eallum Posted November 20, 2009 Share Posted November 20, 2009 Hi, Recently changed the transmission oil two times on my 1992 SC400 with ATF T4 since it had not been changed for a while and the fluid was no longer red-ish, more like brown in color. However after the second change, the transmission is disengaging in either reverse or forward drive gears usually right after a cold start when I assume that the transmission oil is cold. This appears to only occur when the car comes to or slows to a stop. For example after starting the car and reversing on the driveway and slowing down to a stop, it sometimes disengages and it would reengage after waiting a short period of time. The same happens when driving forward. What is the likely cause of this problem? Would a slight over fill cause this (hot fluid range reading on dip stick when oil is cold)? Would debris or dirty filter cause this? Quote Link to comment Share on other sites More sharing options...
