Need Some Advice
tpnotch420
My wife has a 1997 ES300 in need of a replacement catalytic converter. It looks like there are a couple of options.
I can either order the direct fit cat and pipe setup for around $200 from Catco or I can have a new cat welded onto the exsisting pipe.
Is either of these options better the the other outside of the obvious pricing difference?
Thanks for any advice you can provide
Here are some of the symptoms to ensure I'm going down the right path
1st the engine makes a constant noise (like the sound you make when giving someone a rasberry) and it gets louder as you accelorate.
2nd an occasional loss of power or hesitation
3rd I'm starting to smell exhaust fumes inside the car
1. can be just loose or rusted heat shield
2. so many otherthing can create hesitation
3. oil on exhaust (by oil leak from valve cover)
