2005 Gx470 Rear Brakes Need Help Please
jaysond1001
HELLO ALL I AM NEW TO THE FORUM AND FIRST TIME DOING REAR BRAKES ON MY GX470 I FIRST NEED HELP WITH THE JACKING UP PROCEDURE is THERE AN OFF SWITCH FOR THE RIDE HIEGHT / AIR PUMP thank you
Center console, above the ride height control switch, small button that says "off", push it and that should disable the air suspension.
