2002es300TX Posted October 25, 2009 Share Posted October 25, 2009 When he uses the remote to unlock the doors 3 of the doors unlock but 1 does not. Any idea why this is happening? Is this common? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted October 25, 2009 Share Posted October 25, 2009 The problem could be a failed lock motor/actuator/solenoid -- people seem to use different terms for the same part. It is not a real common problem but certainly has been reported multiple times for the ES on this forum. Do a search on "actuator" or "lock" in the ES forum and you will find other threads about this problem. Here is a diagram of the front passenger door that shows the lock mechanism: http://www.toyodiy.com/parts/p_U_2002_LEXU...EAGKA_6703.html Quote Link to comment Share on other sites More sharing options...
2002es300TX Posted October 26, 2009 Author Share Posted October 26, 2009 The problem could be a failed lock motor/actuator/solenoid -- people seem to use different terms for the same part. It is not a real common problem but certainly has been reported multiple times for the ES on this forum. Do a search on "actuator" or "lock" in the ES forum and you will find other threads about this problem. Here is a diagram of the front passenger door that shows the lock mechanism: http://www.toyodiy.com/parts/p_U_2002_LEXU...EAGKA_6703.html Thank you for the reply. I should have been more specific. The drivers lock doesnt open but the other 3 do. :) Quote Link to comment Share on other sites More sharing options...
