h8snow Posted October 18, 2009 Share Posted October 18, 2009 Trying to find the part number for foam seal that goes between top of radiator and radiator support. Checked with dealer no luck also could not find it searching on line. 1998 ES300 thanks for any help. :) Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted October 18, 2009 Share Posted October 18, 2009 Look at this webpage: http://www.toyodiy.com/parts/p_U_1998_LEXU...TPGKA_1603.html If it is the "CUSHION, RADIATOR SUPPORT" you need, then the part number is 16523-74010 -- $5.04 from http://www.parts.com By the way, your profile says "1998 GS300". Do you also have a 98 ES300? ... just checking ... Quote Link to comment Share on other sites More sharing options...
h8snow Posted October 19, 2009 Author Share Posted October 19, 2009 Look at this webpage: http://www.toyodiy.com/parts/p_U_1998_LEXU...TPGKA_1603.htmlIf it is the "CUSHION, RADIATOR SUPPORT" you need, then the part number is 16523-74010 -- $5.04 from http://www.parts.com By the way, your profile says "1998 GS300". Do you also have a 98 ES300? ... just checking ... Thank you much for the info. The seal i am looking for is an adhesive backed foam strip that was glued to radiator support it closed off the gap between this support and top of radiator. Would really like to replace it as the original came apart. Sorry about profile the car is a 1998 ES300. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted October 19, 2009 Share Posted October 19, 2009 Maybe a sporting goods shop would have adhesive backed foam -- although I don't know if the adhesive would hold up to high heat. I've had sheets of adhesive backed foam come with a a variety of products ... ski boots and helmets, bicycle helmets. Or maybe a radiator shop. Or maybe a Lexus dealer -- a Lexus dealer cut up sheets of adhesive backed form and stuffed them on the insides of my outside mirrors in an attempt to reduce wind noise under a TSIB so maybe dealers have this sort of stuff. Or try a hardware store -- adhesive backed foam weather stripping might work. Quote Link to comment Share on other sites More sharing options...
