Hi,
I have a Lexux RX 300 99. The Engine Computer got damage and I was looking for one online. Manufacturer Part Number of the ECM is 89661-48060. I would like to know is an ECM with 89661-48062 number will also work for my vehicle?
On a site I found it said this below of a 89661-48060 ECM:
Ident: 8966148060
Ident: 8966148061
Ident: 8966148062
Ident: 896614806284
Ident: 896614806484
Does the "Ident" means that they work the same way?
Hi,
Ident: 8966148060
Ident: 8966148061
Ident: 8966148062
Ident: 896614806284
Ident: 896614806484
Be careful with the ecm. I was told by a reputable mechanic that the dealership must "scan it" after installation or else it won't work. Do some research on that before investing the money.
Hi,
Ident: 8966148060
Ident: 8966148061
Ident: 8966148062
Ident: 896614806284
Ident: 896614806484
Alright I'll check how to "scan it". Still I need to know if "Ident" me that it is interchangeable when referring to ECM manufacturer number?
***Still I need to know if "Ident" means that it is interchangeable when referring to ECM manufacturer number?
I would assume "Ident" is an abbreviation for identical. The only one that can give you a certain answer is the site you saw it on, check with them. Be aware that a used ECM is associated with a master key. Once installed in your car the car will not start without that master key. The ECU would need to be re-flashed to allow you to program your keys. If the ECM is supplied with the master key associated with it, you could then program your keys without re-flashing.
