Annabelle Posted October 8, 2009 Posted October 8, 2009 I am new to this group and have a question. My antenna has broke. The motor still works but the actual antenna will not go up or down. Can anyone tell me how to get to the antenna so I can replace any broken parts? Any advice or suggestions are appreciated. Thanks
1990LS400 Posted October 8, 2009 Posted October 8, 2009 Here is a link to a diagram showing antenna parts on an 01 SC430: http://www.toyodiy.com/parts/p_U_2001_LEXU...KAQKA_8604.html You might want to look at the diagram for your car's model year in case it is different. I've seen a thread on this forum on how to replace just the antenna shaft but it would take some searching to find it. I'm not familiar with the SC430 but I assume that trim panels in the trunk have to be removed to access its antenna similar to other models.
Annabelle Posted October 8, 2009 Author Posted October 8, 2009 Thanks so much. I took your advice and found other postings and got the info I needed. Great help!! Thanks again.
