dealmonster1169 Posted September 30, 2009 Share Posted September 30, 2009 2001 RX 300 I have the CEL and VSC light light illuminated with the below codes showing up: C0200- Right Front Wheel Speed Signal Fault C1223- Fault in ABS Control System C1224- Open/Short Circuit in NE Signal Circuit P1130- A/F Sensor Circuit Range/Performance B1-S1 I am planning to replace the ABS Speed Sensor to hopefully correct the first problem. How do I know if I should replace the Air Fuel Ratio Sensor or the Oxygen Sensor to correct P1130? Based on reading some of the other forums, I should look into cleaning the Mass Air Flow Sensor (MAF), but after that which direction do I go? Thanks! Quote Link to comment Share on other sites More sharing options...
diverchris Posted October 3, 2009 Share Posted October 3, 2009 I would suggest, to eliminalte the problem of the Mass Flow Sensor. Its very easily removed form the intke cowling. Once you have it out, clean it then re-install it. Then you need to have the computer reset to see if the error code resets, if not the more expensive sensors might be the problem 2001 RX 300I have the CEL and VSC light light illuminated with the below codes showing up: C0200- Right Front Wheel Speed Signal Fault C1223- Fault in ABS Control System C1224- Open/Short Circuit in NE Signal Circuit P1130- A/F Sensor Circuit Range/Performance B1-S1 I am planning to replace the ABS Speed Sensor to hopefully correct the first problem. How do I know if I should replace the Air Fuel Ratio Sensor or the Oxygen Sensor to correct P1130? Based on reading some of the other forums, I should look into cleaning the Mass Air Flow Sensor (MAF), but after that which direction do I go? Thanks! Quote Link to comment Share on other sites More sharing options...
