namoammo Posted January 21, 2004 Share Posted January 21, 2004 Do you have to replace the entire side marker light or can you just replace the bulb, if you do need to replace it, is it easy? Thanks for your posts!!! Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted January 23, 2004 Share Posted January 23, 2004 You can replace the bulb. The hardest part is getting to it. Quote Link to comment Share on other sites More sharing options...
okiepokie Posted January 23, 2004 Share Posted January 23, 2004 You can replace the bulb. The hardest part is getting to it. How do we actually do it. I am in a similar situation as namoammo. need to replace 1 bulb and replace the other assembly. (Both on the back). Do I have to take it to the dealer for bulb replacement? Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted January 24, 2004 Share Posted January 24, 2004 You should be able to remove your inner wheel well plastic by removing the bolts that hold it in. After that you can reach the back side of the light and remove the bulb for replacement. Reinstall the wheel well and you are back in business. It is sometimes easier if you first remove the wheel. Quote Link to comment Share on other sites More sharing options...
