malboro Posted September 20, 2009 Share Posted September 20, 2009 Hi everyones, I just got a 2006 RX400 but I'm not able to use the gps when the car is not running. if I press on "dest" "menu" or "map" button, nothing happen if the car is not running even if the key is in ACC mode. Is it normal or there is a problem whith mine ? If it is a problem, someone have an idea of the solution ? The only thing I see when the car is not running is the Consumption menu. Thanks for your help Quote Link to comment Share on other sites More sharing options...
malboro Posted September 20, 2009 Author Share Posted September 20, 2009 Hi, I would especially know if it's normal or not. I think it's strange to be unable to use the GPS without having the car start... Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 21, 2009 Share Posted September 21, 2009 You are correct. I MUST start my RX before being able to enter an address into the GPS screen. Quote Link to comment Share on other sites More sharing options...
malboro Posted September 21, 2009 Author Share Posted September 21, 2009 thanks a lot for the answer. Are you able to access "dest" "menu" or "map" buttons without having your car start ? Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 21, 2009 Share Posted September 21, 2009 I believe the map is displayed but I can't remember which "buttons" are shown. Certainly, there are very limited functions available. Quote Link to comment Share on other sites More sharing options...
