Will the upper left control arm for a 95 LS400 work on a 94 LS400?
OEM Part#: 48630-59015 94 and later , check your mfg date:1994 V8 Front Left Upper From 11/94 w/ Ball Joint
before 11/94, they are different
LEXUS LS400 1990 - 1994 UPPER CONTROL ARM RH (PASSENGER) part# 48610-50020
LEXUS LS400 1990 - 1994 LEFT UPPER CONTROL ARM LH ( PART # ) 48630-50020
Thanks, where do I look for that date?
open the drivers door, and you will see a white sticker like the one below,
look at the top line, production date is at top right.
on this sticker it is 1/97
check yours out.
good luck. bp
