has anyone had thier nav working just fine and then all of a sudden you look at it and your hundreds of miles away the other day my wife drove around the gulf of mexico for a few days i did a recalibrate and its been fine but it has done this three time 06 gx 470 black
Do a diagnosis by doing a navigation check from the menu. In this mode you can do a check , you will have in this Sequence. GPS Information, Vehicle Sensors, Color Bar, etc...Click on GPS Information , Start the Diagnosis, and check the GPS related information. Once received check out the level of Signal, it should read higher, chech the rest ie position data and time data.
Ensure to this at an wide open area clear of any obstacles.
thanks i took it in on friday they could not find anything wrong but it has been ok for about three weeks now.
  • 7 months later...
well i have the same problem again my nav. is lostthe dealer is trying to blame it on my rear dvd i had installed the problem is that it did it before i had it installed and is doing about 5 m0nths after the dvd was installed i now have 49672 miles i think i am getting the run around they showed me the diagnostic screen it shows my lat and long but they say it shows no sat. signal all 0's on that line but yet the gps followed me down the road for awhile and now my sat radio won't work since i left i really need someones help.
  • 2 months later...
I just wanted to let everyone know my 06 GX 470 has been at Lexus of Tampa Bay for 8 weeks and i just got it back on monday and they came to pick it back up today the navigation still does not work right and now my satellite radio does not work they replaced the wiring harness in the dash the antenna cable and antenna but when you check the nav screen you only have 3 to four sats and 2d most of the time and the time on the gps is wrong it about 6 hours off needless to say this has been a nightmare.
I've had a similar problem, but it was the sat radio causing the gps to get lost. When I pulled it out to get it(the radio) checked the GPS went back to working great. Do you have add on or factory sat radio?
i have an add on sat radio the nav is now working but now we do not have the sat radio. and just so everyone knows to they forgot to hook my dvd player back up so it went back for that they called a day later and said it was ready when i got to lexus of tampa bay i turned on the radio and the screnn said audio off they had to take it back in the shop they forgot to plug the radio in this time.
