I have a '94 LS400 and I drive an hour away to get to work, today everything was fine until I get to work early and sit with my car idling. The engine almost stalls a few times, and then the check engine and TRAC OFF lights come on.
I checked again at lunch and the idle problem got worse ( still didn't stall but almost). When I drive now, the warning lights stay on, and my acceleration has diminished as well as my air-conditioning. Does anyone have a similar problem with a solution?
There is a link on lexls.com to pull the trouble codes from the ECM. You can then know if you have a bad coilpack, injector, or other part that's causing the issue.
