Check Engine Light On, O2 Sensor Code
Max Power
91 LS400, O2 sensor was changed but the check engine light is still on. Apparently this causes the traction control to be off?
Anyone have any ideas?
You need an ODBII read to clear the code OR dis-connerct the battery cable for 30 second or so. I just replace all my O2 sensors (4 of them) and the 2 sub-sensors are a pitty to take off
not true, if u want to reset the computer then disconnect the efi fuse under the hood...u dont need an obd reader of any kind
