aparker Posted August 17, 2009 Share Posted August 17, 2009 Help! After immediately changing my battery, my dash lights no longer worked. When the head lights are turned on (not auto), the dash lights go completely dark; however, when the head lights are in auto the lights are very dim. I am thinking this is some kind of relay. Anyway, someone please englighted me. I have a 1999 GS 300. Quote Link to comment Share on other sites More sharing options...
alphanumberz Posted October 3, 2009 Share Posted October 3, 2009 Did you check your FUSE? Or maybe you need to adjust the light switch by the steering wheel, you probably dimmed it down. Quote Link to comment Share on other sites More sharing options...
drewd2385 Posted February 5, 2013 Share Posted February 5, 2013 i have the same problem and need this answer also cheack to c if u get clicking by the bay of drivers feet i think its a bcm moduel???? Quote Link to comment Share on other sites More sharing options...
ivnnln Posted February 16, 2013 Share Posted February 16, 2013 This is may be a dump question, but did check to make sure that both battery terminals are tight and secure? Quote Link to comment Share on other sites More sharing options...
drewd2385 Posted February 18, 2013 Share Posted February 18, 2013 yes i actuly think i found the problem i started hitting the top of the big fuses under the hood it turned out to be a green one closest to the motor but now my car wont charg but when i pull it i think it chargers so im going to change tomorrow and go from there Quote Link to comment Share on other sites More sharing options...
drewd2385 Posted May 2, 2013 Share Posted May 2, 2013 I know for sure what it is its ur fuse box one of the major fuses u probably burnt a whole between the contacts that is what happened to mine u need to take the pannal out of the box and inspect it and u should find ur problem Quote Link to comment Share on other sites More sharing options...
