Power Steering Pump Seal Replacement
ehancock
After fixing the starter I noticed my PS fluid is low. The seal is starting to leak. I see from pictures in the lexus service manual that it may be possible to simply pull out the shaft and bearing, then the seal, without complete dissassembly. Then I would press in a new seal and reinsert shaft and bearing.
The shaft has a spline fit into the pump rotor and should just slip out and back in, at least it looks that way.
Has anyone done this successfully?
Ernie in Vancouver BC Canada
