craig27 Posted August 9, 2009 Posted August 9, 2009 Quicky question. Can anyone provide the torque spec for the wheel lugs? I cant seem to find it in the manual. I need to have it to remind the guys at the tire shop when they balance/rotate. Along w/ over-inflating, they seem to want to use an impact set at 5000ft/lbs when putting wheels back on. For each of my cars, I make a small laminated placard that has front/rear tire pressure along with torque specs. I set it in a conspicuous place when I drop it off so their is no confusion. Has worked pretty well so far. Thanks!
KBRX330 Posted August 9, 2009 Posted August 9, 2009 Quicky question.Can anyone provide the torque spec for the wheel lugs? I cant seem to find it in the manual. I need to have it to remind the guys at the tire shop when they balance/rotate. Along w/ over-inflating, they seem to want to use an impact set at 5000ft/lbs when putting wheels back on. For each of my cars, I make a small laminated placard that has front/rear tire pressure along with torque specs. I set it in a conspicuous place when I drop it off so their is no confusion. Has worked pretty well so far. Thanks! My ES350 is 76 ft lbs. I have had the same issue and now do my own rotations. The last gorilla that rotated my tires cranked them on over 100 ft lbs. I write it under the hood with a silver sharpie along with the oil weight & capacity just in case the wife takes it to a shop and I am not there to tell them.
