MikeB1 Posted August 4, 2009 Posted August 4, 2009 How do I change the drivers side turn signal lamp? I have a 1999 Lexus ES-300
1990LS400 Posted August 5, 2009 Posted August 5, 2009 How do I change the drivers side turn signal lamp?I have a 1999 Lexus ES-300 Would you be talking about the front or the rear?
MikeB1 Posted August 5, 2009 Author Posted August 5, 2009 How do I change the drivers side turn signal lamp?I have a 1999 Lexus ES-300 Would you be talking about the front or the rear? The Front.
1990LS400 Posted August 6, 2009 Posted August 6, 2009 It looks like you have to remove the front turn signal housing just like on my 00 LS400. Remove the one screw and pry the turn signal out by using your fingertips between the headlight lens and the turn signal assembly. It's held in mainly by friction fittings -- about all the one screw does is to make the turn housing difficult to steal. An illustration is here: http://www.toyodiy.com/parts/p_U_1999_LEXU...TPGKA_8103.html
